Group: DynoMotion Message: 11794 From: Tapio Larikka Date: 6/27/2015
Subject: Re: Limit switch options?-SOLVED
It looks that the cause was my init file that loads at boot. Apparently the step response/move does not override the limit switch options set in the init file.
Rgds,
Tapio
----- Original Message -----
Sent: Friday, June 26, 2015 5:18 AM
Subject: Re: [DynoMotion] Limit switch options?
Hi Tapio,
I assume you tried this with Stop When Low checked or unchecked?
One remote possibility is that noise is causing the signal to be both high and low (with a small duty cycle so it may not be seen on the Digital I/O Screen).
Try running these two test routines to check for that and report the results (test in the inactive state):
// Simple check for Glitch on Input Pin
    while (!ReadBit(1106)) ;  // tight loop while input is low
    printf("Input was high!!\n");
    while (ReadBit(46)) ;  // tight loop while input is low
    printf("Input was low!!\n");
Group: DynoMotion Message: 11800 From: Tom Kerekes Date: 6/27/2015
Hi Tapio,
Any Init file that runs at power up would indeed change parameters.  But if it only changes them once and if you download new parameters from KMotion Screens (ie "Move") those should set new values.  So I'm not sure why you see this effect unless your Init.c program is continuously executing in a loop or something.  What is the program you are flashing in KFLOP?  We don't recommend you have Launch on Power up programs as it can be confusing what was flashed in each board.  It is usually better to leave KFLOP in a completely default state and just Initialize it from the PC with an Initialize Button.
Group: DynoMotion Message: 11807 From: Tapio Larikka Date: 6/27/2015
It ends up the cause was me not seeing the obvious, once again.
I have virtual bit stated based limit options in for;; loop at the end of my init.c file. I have these so that hitting the limit will trip mach reset but to allow jogging off the limit once limits are deactivated.
Thank you once again,
Tapio
Sent: Saturday, June 27, 2015 9:05 PM
Subject: Re: [DynoMotion] Limit switch options?-SOLVED
Hi Tapio,
